Volkstock tech weekend Sept 24-26
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
Post new topic   Reply to topic    AthensVWClub.com Forum Index -> Shows and Events
PostPosted: Wed Sep 01, 2010 1:51 pm    Post subject: Reply with quote
Hell, I do that all the time...
discobus
PostPosted: Thu Sep 02, 2010 8:36 pm    Post subject: Reply with quote
Jon wrote:
I'm in for Saturday morning valve adjustment and also checking timing. I've got some air-horns I'd like to install on the Thing, but may need a little guidance on wiring.
Wiring is my favorite... air-horns are always good.
Are going to run them from the stock horn button or seperate switch?
I need to fit a new split charger to hattie if anyone is interested in how they work?
See you soon...
Pete.
PostPosted: Thu Sep 02, 2010 9:05 pm    Post subject: Reply with quote
Are going to run them from the stock horn button or seperate switch? Stock button would be cool
I need to fit a new split charger to hattie if anyone is interested in how they work? I would like to see this too!
See you soon...
Pete.
What supplies do I need to hook up the horns?
PostPosted: Thu Sep 02, 2010 9:37 pm    Post subject: Reply with quote
If there's room (and time) I would love to bring my '74 Thing for a clutch replacement!. (Clyde? Got clutches? it's for a dual carbed 1914)
Also got a serious vibration in the frontend (steering dampener or ball joints?) that needs attention.
'58 RHD 2110cc Beetle
'74 Thing
PostPosted: Thu Sep 02, 2010 9:58 pm    Post subject: Reply with quote
I've got OE brand Chinese, Sachs, and Kennedy Stage 1 clutches in stock. I've got thing ball joints in stock too. Need a H beam press to squirt them into your arms though. Is there a place in Bethlehem that'll do this on a Sat.? (if not, I can bring them to my work, or maybe we can find a C-clamp style press to try?)
What is a split charger? I'm guessing a switch to select which battery to charge in a two battery system? James? Help?
How about a teeny "Booty Pop" under the heat shrink tubing?
PostPosted: Thu Sep 02, 2010 10:13 pm    Post subject: Reply with quote
I'll call ya tomorrow Clyde. ; )
'74 Thing
discobus
PostPosted: Thu Sep 02, 2010 11:12 pm    Post subject: Reply with quote
See you soon...
Pete.
Are they compressor run or single unit electric?
Some stock GA16 or 18 cable and crimps to fit probably all it needs. I have a good selection on hand you don't.
Are going to run just the horns? or want to switch between stock and air-horns, if so a DPST switch would required.
-Pete.
PostPosted: Fri Sep 03, 2010 8:33 am    Post subject: Reply with quote
I have acess to a 48" heavy duty table clamp for wood projects
how strong does it need to be?
later
Jeff
Jeff Epperson
Blowin Smoke BBQ
PostPosted: Fri Sep 03, 2010 10:05 am    Post subject: Reply with quote
I use a 50 ton press at work for ball joints. I think a 10 ton would work. Never tried the C-clamp style press that's meant just for ball joints, but If I find one for $50 or less, I'll give one a shot. Saw one at ReTool a month ago, only I had $5 in my wallet, and never made it back. Rolling Eyes
A regular C clamp will twist up like a pretzel doing ball joints. Thanks for trying, though
discobus
PostPosted: Fri Sep 03, 2010 11:43 am    Post subject: Reply with quote
Is anyone good at front wheel alignment? in particular with lowered buses??
I was kinda able to follow the hippie book with couple of tubing push sticks and got reasonably close when Hattie stock height, but since then have had some troubles both with toe-in and vertical angle. Net result was a set tires that I had to replace due uneven wear Sad
My last go around it is definitely closer, but I have a feeling it's still off a little. If there is wheel aligning guru I would very interesting learning what I'm doing wrong Wink
-Pete.
PostPosted: Fri Sep 03, 2010 12:26 pm    Post subject: Reply with quote
-Pete.
That's easy....you're lowering the bus. Rolling Eyes Laughing Laughing Stock height rules! (unless you are 18 & don't know better)
PostPosted: Fri Sep 03, 2010 12:37 pm    Post subject: Reply with quote
The main thing is getting the link pin shims right, and then adjusting the tie rods. I've done beetles, but never a bus. Which do you think was worse, the caster or toe? Considering the price of tires, it's worth paying a pro to get the toe in right. Unfortunately, no pros will touch the link pin setup. I'm no guru, but I'll try anything party0006
PostPosted: Fri Sep 03, 2010 10:40 pm    Post subject: Reply with quote
Sorry Clyde Embarassed I forgot to call, I'll try again tomorrow.
'74 Thing
DiggerD
PostPosted: Mon Sep 06, 2010 8:07 pm    Post subject: Reply with quote
I would like to install a new rear window seal in the 71, and possibly fix a pesky exhaust leak on the bus.
and....
I promise not to go near any wheels or wheel attachment devices this year............ Shocked
Wink
D
66 Bus
71 Eriba Puck
discobus
PostPosted: Mon Sep 06, 2010 11:27 pm    Post subject: Reply with quote
Not unless you bring your own pressure washer! Smile
Post new topic   Reply to topic    AthensVWClub.com Forum Index -> Shows and Events All times are GMT - 4 Hours
Page 2 of 7
