Posted: Wed Sep 08, 2010 11:10 am Post subject: Speedometer |
I noticed on the way in to work this morning,the speedometer needle was jumping 5 to 10 mph up until 50 mph then the needle would stop jumping and smooth right out like it was supposed to act?
Is this just Grease needed to add to cable or other problems?
Thanks for the info
Jeff E. _________________ Jeff Epperson
Blowin Smoke BBQ |
Ruptured Duck
Joined: 28 Dec 2009 Posts: 59 Location: Gainseville Ga
Posted: Wed Sep 08, 2010 11:50 am Post subject: |
Sounds like the cable.... Mine just broke so I need to get a new one as well.... I would try lubricating it to see if that helps. Its binding up and then releasing causing the Jump. If it's starting to let go small wire strands will split and brake. These sometimes catch the cable housing causing the slight stall (jump).... Old Jeep speedos do the same thing. People replace perfectly good units not relaizing that it's only the cable. |
Posted: Wed Sep 08, 2010 12:25 pm Post subject: |
Thanks !
How much does a new one run $$ .
I will lube it tonight and see if it helps.
L8ter
Jeff _________________ Jeff Epperson
Blowin Smoke BBQ |
Posted: Wed Sep 08, 2010 9:00 pm Post subject: |
'58-'74 T1 cable is $11.00
Thanks for asking. _________________ '69 Bug, 1776, dual kadrons, Web 111 cam
Posted: Thu Sep 09, 2010 7:22 am Post subject: |
Clyde wrote: | '58-'74 T1 cable is $11.00
Thanks for asking. |
You got one in stock ?
How are they on instalation? _________________ Jeff Epperson
Blowin Smoke BBQ |
Posted: Thu Sep 09, 2010 7:55 am Post subject: |
Got 4 of 'em. Not too bad to install. Just put it through the holes the old one came from. _________________ '69 Bug, 1776, dual kadrons, Web 111 cam
Posted: Thu Sep 09, 2010 7:58 am Post subject: |
Clyde wrote: | '58-'74 T1 cable is $11.00 installed.
If you buy from Clyde you don't have to worry about installing it. _________________ 73 Typ481
Posted: Thu Sep 09, 2010 8:36 am Post subject: |
Jon wrote: | Clyde wrote: | '58-'74 T1 cable is $11.00 installed.
If you buy from Clyde you don't have to worry about installing it. 8) |
Thats why i buy from Clyde he dont mind teaching the Vee Dub Dummies like myself.
Blowin Smoke BBQ |
Posted: Sat Sep 11, 2010 9:19 am Post subject: |
Hello Clyde
If its not a problem and your going to be around sometime today sat,
call me if i can shoot up there and pick up that speedometer cable
i'm just messing around all day saturday.
404-886-8120
Blowin Smoke BBQ |
Posted: Mon Sep 13, 2010 7:37 am Post subject: |
Picked up a new one !
Thanks Clyde _________________ Jeff Epperson
Blowin Smoke BBQ |
