73SuperBug
1973 Volkswagen Super Beetle
Posted: Tue Apr 24, 2012 9:38 pm Post subject: Starter noise |
Pulled engine to replace pushrod tubes. Put motor back in with no issue. Now when it cranks the starter makes a God awful noise the the motor fires up just fine. Any ideas on the noise and what to do to resolve it. It does not sound good!!
My VW History:
73 - Super: Present
71 - Super: 1995 - 1998
74 - Super : 1975 - 1984 _________________ 73 SB - Present
71 Bug
74 SB |
JOHNB
1967 Volkswagen Beetle
Posted: Wed Apr 25, 2012 5:01 pm Post subject: |
Is yours an auto,and if not did it have a bushing in the end of it?If its manual make sure your put the bushing in place.I believe that is correct.I had the same problem on my 67 and i had to put the bushing back in. _________________ "Dream like you will live forever,and live like you will die tomorrow"
James Dean |
Posted: Wed Apr 25, 2012 7:43 pm Post subject: |
Maybe the starter shaft needs a touch of grease?
Or your flywheel isn't torqued to 300 ft lbs
Or there's a grizzly sleeping under it who doesn't want to be disturbed _________________ '69 Bug, 1776, dual kadrons, Web 111 cam
73SuperBug
Posted: Wed Apr 25, 2012 8:55 pm Post subject: |
I put a touch on the tip that goes in the bushing. Did not remove the flywheel. I checked for the bear. I was hoping that was it. The only other change was a new ignition switch. _________________ 73 SB - Present
71 Bug
74 SB |
