bench bleeding / brake overhaul
PostPosted: Fri Oct 19, 2012 2:21 pm    Post subject: bench bleeding / brake overhaul Reply with quote
If I'm replacing the master cylinder, do I / should I bench bleed it?
PostPosted: Fri Oct 19, 2012 2:51 pm    Post subject: Reply with quote
yep, it helps out
73 Super
68 Single Cab
PostPosted: Fri Oct 19, 2012 3:11 pm    Post subject: Reply with quote
cool, I'll ad it to the list, thanks
PostPosted: Fri Oct 19, 2012 3:30 pm    Post subject: Reply with quote
I've never bench bled a VW master cylinder and I always stop. Shocked
PostPosted: Fri Oct 19, 2012 8:15 pm    Post subject: Reply with quote
Replace the master and fill the reservoir.. Crack open the rear bleeders and walk away. After about 10 minutes you'll see fluid leaking out of them. Close the bleeders and do the same thing on the front bleeders. Once they have drip bled you have effectively bench bled the master and the entire system.
Start at the rear cylinders and bleed them conventionally, you'll see that you only have to pump them about twice to get clear fluid out of them.
This works and is very simple.
PostPosted: Sat Oct 27, 2012 6:51 pm    Post subject: rear brakes Reply with quote
Thanks for the advise. I bet it would work great....except...I didn't check my bleeder valves before I started this process. One is sheared off (before I bought it) , the other will be shortly if I continue. I think I can replace the calipers but I don't have a way of getting the nut off/on. Any thoughts?
Also, anything else to replace besides the calipers and brakes to replace once I'm in there?
PostPosted: Sun Oct 28, 2012 9:59 am    Post subject: Reply with quote
I can drill out your broken bleeder screws if you want. Alot cheaper than buying new Bus calipers.
PostPosted: Sun Oct 28, 2012 12:16 pm    Post subject: Reply with quote
Sorry, I meant wheel cylinders, I'm so used to talking about disc brakes. I've never been into drum brakes. Wonder if it's pretty straight forward. (i just replaced the master cylinder and booster). I'm kinda worried about getting the axle nut off. (Assuming I need to)
PostPosted: Sun Oct 28, 2012 2:56 pm    Post subject: Reply with quote
If this is for your bus, the big nut doesn't need to come off to remove the drum.
PostPosted: Sun Oct 28, 2012 5:28 pm    Post subject: Reply with quote
Awesome, I may try to tackle it this week then, thanks
