Using Westy onboard propane system for other uses
PostPosted: Sat Jul 25, 2015 11:43 am    Post subject: Using Westy onboard propane system for other uses Reply with quote
So I took out the stove from my Westy, which left the onboard propane system still intact. I figured I could use the propane to run a small heater (little buddy etc.) to heat the bus in the colder months. I could have just used the small disposable cylinders but I like to use as much of the bus as possible. So, if any one else is looking to do the same, I've included the fittings/parts I used below.
LFA-182 3/8 flare X 1/4 MIP
LFA-732 1/4 FIP
4 ft. hose 3/8 male flare on both ends
Mr. Heater F273755 LP Cylinder Adapter 1" 20MX1/4 Adapter
So now, anything that uses the small disposable propane bottles, I can run off the big Westy tank.
PostPosted: Sun Jul 26, 2015 10:19 am    Post subject: Reply with quote
I hope you got two of each of the components!
PostPosted: Sun Jul 26, 2015 2:06 pm    Post subject: Reply with quote
Always Very Happy
