Place your bets. |
Yes |
66% |
[ 2 ] |
No |
33% |
[ 1 ] |
Total Votes : 3 |
Fat Boy Motors
Joined: 08 Jun 2006 Posts: 15 Location: Jefferson, GA
Posted: Wed Jun 14, 2006 3:39 pm Post subject: 100 hp motor uder $900.00 ??? |
I have a few motors to finish up for Joey. When they are done I'm going to start on a motor for my 68 ghia vert. I think I can build a motor to turn out over 100 hp on a $900.00 Budget. I'm not talking about cutting corners. I'm talking about a dependable daily driver 100 hp. My Goal is to have it done by Dyno days. $900.00 - 9 months - 99.99+ hp. Did I mention 1776 cc????
What do you think? Can it be done _________________ It's the pedal on the right, Now stomp it!
Rice it's what's for dinner. |
Posted: Wed Jun 14, 2006 6:04 pm Post subject: Re: 100 hp motor uder $900.00 ??? |
What do you think? Can it be done [/quote]
What you been smokin? Can it be done? Yes...for$900.00...NO
heads and carbs will cost you that.
I hope you can, but it ain't bettin on it. _________________ 73 Typ481
Posted: Wed Jun 14, 2006 10:51 pm Post subject: |
I would like to place my order for 3 of dim enguns!
1 fo the weekdays
1 fo the weekend
& 1 real one while the other 2 is bein' fixed!!! |
Fat Boy Motors
Posted: Wed Jun 14, 2006 11:12 pm Post subject: |
As long as you plan on paying labor cost Monkey Boy you got it. I need to add a few more details I have a case, Crank, Heads, and a Cam. Also that is at the fly wheel. I Plan on 9 to 1 compression, Porting and polishing done by yours truly, Carbs to save money will probaly be Kardons, Staight cut gears lightend fly wheel, 1.4 to 1 rockers, valves are 42x37. I'm figuring 30 percent loss of hp to the wheels so 70 hp or higher reading on the dyno will mean victory. _________________ It's the pedal on the right, Now stomp it!
Fat Boy Motors
Posted: Wed Jun 14, 2006 11:16 pm Post subject: |
Let's Make it a little more interesting. If it comes up short I will sell it for what I have in it. _________________ It's the pedal on the right, Now stomp it!
Posted: Thu Jun 15, 2006 7:21 am Post subject: |
If it comes up short, why would I want to buy it? _________________ 73 Typ481
Posted: Thu Jun 15, 2006 7:37 am Post subject: |
Sounds doable, but how many miles will you get out of it? It sounds like a large amount of reused parts (which is wise in the goal of saving $) I'm not looking for an argument now. I just want to see the same motor without splitting the case in 5 years, with moderate driving wear on it. And see the temps and oil pressure, etc. |
Fat Boy Motors
Posted: Thu Jun 15, 2006 8:06 am Post subject: |
I'm going to use a used case line bored, A use crank cut 10/10 used heads, New valves, springs,and keepers, a used balanced fly wheel, rebuilt carbs, so it's not like I'm using used cams, lifters, pistons and jugs. Now as far as temps and oil pressure: full flow-all new bearings. Now 5 years of moderate driving, If I keep it the world will never Know, Not real sure what moderate driving means. _________________ It's the pedal on the right, Now stomp it!
Posted: Thu Jun 15, 2006 5:22 pm Post subject: |
Jeff,
We all knew you had no idea of what moderate driving is.
To me, moderate driving is: driving in a way that doesn't blow something up before it wears out. No sidestepping the clutch, or lugging it, or revving to 6K in every time I go somewhere.
Your plan sounds good to me. Add balancing and go for it. |
rustyfastback
Joined: 15 Jun 2006 Posts: 71 Location: Stone Mountain, GA
Posted: Thu Jun 15, 2006 9:40 pm Post subject: |
Jeff, tried to do a burnout in a '61 vert with a 36hp motor. He was trying to speed shift that old vert also. I know he will break that 1776 in right _________________ Give me a salad & a PBR please |
